Home
Forums
Routes
Gear Reviews
How to contribute
Personal setups
Trip reports
Ultra records
Help
Search
Login
Register
Bikepacking.net forums
Forums
Question and Answer
Thudbuster + Revelate Designs Seat Bag
Pages: [
1
Topic Name: Thudbuster + Revelate Designs Seat Bag
on: April 11, 2015, 06:36:01 PM
tdurack
on:
April 11, 2015, 06:36:01 PM »
https://www.revelatedesigns.com/blog/index.cfm/2013/10/24/Thudbuster-seatposts-and-Packs
"We're just going to run through the combos, before that however, we want to note that the rear saddle clamp bolt is quite nasty on bags. If left un-treated this bolt WILL WEAR A HOLE IN YOUR BAG. We recommend replacing it with a smooth head bolt, or abundant use of a file to round off the sharp teeth."
Anyone done this? Looks like an m5x35mm.
Tim:>
Reply #1
on: April 11, 2015, 08:54:27 PM
Kiwi Pete
aka: Kiwi Pete's Adventures
Re: Thudbuster + Revelate Designs Seat Bag
Reply #1 on:
April 11, 2015, 08:54:27 PM »
Hi Yes
I filed the sharp teeth off a little!
Would next time just replace the bolt, as still worn the seat bag a little.
All the best
Bikepacking New Zealand
https://bikepackingnewzealand.co.nz/
Reply #2
on: April 13, 2015, 12:38:57 AM
Alaskamatt
Reply #2 on:
April 13, 2015, 12:38:57 AM »
I replaced the bolt. It's 5x something more than 30. Longest I had available to me was 5x30 and it works.
Reply #3
on: April 13, 2015, 01:35:29 AM
falkenjaeger
Reply #3 on:
April 13, 2015, 01:35:29 AM »
It can be an issue indeed but I realized it before it was too late. I used a piece of an old tire between the bolt and the viscacha and fixed the thire with two zip ties around the stem. Works pretty good so far.
Arriva Mexico!
Reply #4
on: April 13, 2015, 05:10:53 PM
tdurack
Reply #4 on:
April 13, 2015, 05:10:53 PM »
For the record, Cane Creek said: "Yes you can replace it with a round head M5x35 but it does use a orbital washer and bolt head, to keep the load on the bolt head even. So you will want to try to find a bolt with an orbital head. Or you can try padding the current bolt with a wrap of old tube or foam."
Reply #5
on: June 18, 2015, 05:55:55 AM
trailhead
Reply #5 on:
June 18, 2015, 05:55:55 AM »
Another thing to consider is clearance between the bottom of the bag and the wheel. My bike has a small frame and as the seatpost went through its travel, the bag would rub against the wheel.
Reply #6
on: June 18, 2015, 06:11:09 AM
sherpaxc
Reply #6 on:
June 18, 2015, 06:11:09 AM »
Mine did that too, but I solved that issue by running an extra stra through the seat rails and around the bag and cinched it up real tight. Winner winner...
Reply #7
on: July 09, 2015, 08:31:26 PM
Smithhammer
Reply #7 on:
July 09, 2015, 08:31:26 PM »
I put one of these little plastic screw protectors (cheap and available at just about any hardware store) on mine. Works great.
- Benny Hill
Pages: [
1
Please select a destination:
Forums
=> Bikepacking
=> Question and Answer
=> Routes
=> Ultra Racing
=> Winter bikepacking
=> Classifieds
Site
=> Site issues / Suggestions
Powered by SMF 1.1.21
SMF © 2015, Simple Machines
Loading...
