  Topic Name: roll top frame bag on: March 04, 2012, 06:49:07 PM
« on: March 04, 2012, 06:49:07 PM »
I sewed my first frame bag a couple of years ago.  I think a roll top will out last a zipper bag.
If I make a second one, I will add 2 inches or so to the top straps, and make the side and bottom
straps shorter.
  Topic Name: roll top frame bag Reply #1 on: March 06, 2012, 10:38:00 AM
« Reply #1 on: March 06, 2012, 10:38:00 AM »
Interesting! Does the entire top of the bag drape over the top tube, or does it roll up under and then have a flap on the other side? You may have just created the basis for dry-frame-bags.
  Topic Name: roll top frame bag Reply #2 on: March 06, 2012, 11:15:39 AM
« Reply #2 on: March 06, 2012, 11:15:39 AM »
The entire top of the bag goes over the top tube.
The mistake I made was to measure the top straps with an empty bag.  Full, the top straps need another inch or 2.  It works so I did not correct the mistake.
I cut one continues strip of fabric + - 2 inches wide (+5/8 seam allowance on each side,) for the bottom and sides.  I used a piece of news paper to make a pattern for the 2 side panels.  The side and bottom straps were sewn into the seams.  There are 2 Velcro straps in the interior to stop it from puffing out at the sides.
It is just a simple bag cut to bicycle proportions.
I prefer the roll top because:
Easier to sew.
More leeway to switch bikes
Should out last a zipper bag
  Topic Name: roll top frame bag Reply #3 on: March 06, 2012, 11:23:35 AM
« Reply #3 on: March 06, 2012, 11:23:35 AM »
I cut this bag to the size of two 2.5 liter soda bottles. I use it to carry 5 liters of water.
edit
Hm-mm;  it took a few minutes for that statement to soak in.  Would you modify a store bought dry bag to fit a bike frame?  Is anyone up to date on some kind of Swiss technical fabric that does truly keep water out?
« Last Edit: March 06, 2012, 12:08:04 PM by chrisx » Logged
  Topic Name: roll top frame bag Reply #4 on: May 12, 2015, 07:07:55 AM
Marna
Riding at Home
« Reply #4 on: May 12, 2015, 07:07:55 AM »
I like your design.  Very Clever!  Zippers break and then need to be replaced.  With your design (if you keep the velcro clean <smiles>  your Frame Bag might last longer than those made with Zippers.  Something to think about.
Just ride your own bike and have fun!
  Topic Name: roll top frame bag Reply #5 on: May 15, 2015, 04:49:37 PM
« Reply #5 on: May 15, 2015, 04:49:37 PM »
That old bag is still use-able.  I have sewn used and thrown out a couple of zipper bags since then.  I suppose I could have replaced the zippers.  I sewed another roll top bag instead.
At this time I would like to clearly state.
  Zipper-less bags lasts longer, a lot longer.
  Topic Name: roll top frame bag Reply #6 on: May 18, 2015, 11:03:16 AM
wunnspeed
« Reply #6 on: May 18, 2015, 11:03:16 AM »
I assume that's a rhetorical question but.... I'm a bag maker living in Switzerland and I don't know of anything. However, that doesn't mean it doesn't exist. :-)
SpoK Werks Etsy
SpoK Werks FB
Big Wheel Racing Europe
